its a 06 2500 cummins and the heater dosent seem to blow out much heat when it gets cold out.. any mods ya can do i know winter front im looking in to it right now i dont want to buy a wabesto heater.
08 mega 4x4 6 speed auto,h&S Black Max,OD Software, 5" diamond eye exhaust, Sinister delete kit, AFE mega cannon, 5" Rough Country Lift,37" toyo open country
ya ill try that its even in the summer super slow to get up to 190
Dodge has put a thermostat, reflash and flushed out the heater core. Today they put in a new water pump and stated they need to put in a new thermostat which will be in tomorrow. I really don't think that will fix it either. They said that they checked the blend door, so they said and found it was not the problem although I still think it is. The temperature gauge has always been steady and rises at a normal rate to 200*. What do you guys think it could be??
4th Gen. 12 Crew Cab 3500 4X4, 3.73s, auto, Longhorn Dually
2nd Gen. 97 Ext. cab 3500 4X4, manual slightly modded
94 Reg cab 3500 4x4, manual with flat dump and plow
1997 Ext. cab 1500 4X4, manual, 318 gas
54 Job Master, 14' flat
does yours barley move any air either? cause i had my ac fixed this summer and now the fan seems not to work but sounds like it blows like crazy its still warm but still drives me nuts.
TY-06 6 speed, TDK bumpers, no muffler, power pup, bd intercooler, boost fooler, afe stage 2, south bend, one piece driveline, autometer gauges, 2'' leveling kit, 35 12.50 toyo mt's, 18" XD Badlands, "IT'S NOT WHAT YOU BUY IT'S WHAT YOU BUILD"
Mine moves plenty of air it is just not hot. I flushed the heater core both ways several times and this morning it put out good heat for about 20 miles then back to barely warm again. It is back to the dealer now.
I'm probably stating the obvious but something is wrong with your heater. My 06 gets so hot inside it will make you sweat. Even when it is 25 outside.
Is your AC on all the time like it's stuck in defrost mode?
