How hard to replace door lock actuators? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-16-2009, 11:11 AM Thread Starter
justinduke's Avatar
My power door locks haven't been working for awhile now so I finally took it to the dealership to diagnose the problem. They tell me all 4 actuators are out(they didn't go out all at once). Was just wondering how hard it would be to install them myself and how long it takes? They were wanting $200 labor to do it so I figured it would be better to do it myself. Anyone replaced them before?
2006 Auto Mega Cab 4wd
RIP - Early 2004 SRW 3500 6spd CTD 4wd
justinduke is offline
post #2 of 8 (permalink) Old 09-16-2009, 11:12 AM Thread Starter
justinduke's Avatar
Also is there anywhere to buy the actuators cheaper than the dealership?
post #3 of 8 (permalink) Old 09-16-2009, 01:09 PM
Rbell's Avatar
Not sure about anyone else selling them but they aren't to bad to install, aleast the drivers door isn't. Think it took me about 20 minutes to complete. ROB
05 Ram 3500 Garmon's FULL BILLET 48Re MBRP, AFE stage 2, Auto Meter gauges, Industrial Injection Phatshaft 330 and dragon fly 100hp injectors, Smarty.
Rbell is offline
post #4 of 8 (permalink) Old 09-16-2009, 02:16 PM
iccmiller's Avatar
I would double check what the stealership told you. Personally I would not believe that all four motors are bad without some further investigating on my part.
Check fuse 28 first since it is the easiest to do. If it looks good swap it or replace it with one of the same value/color. It should be 10 Amp.
If this fixes your problem then you save $$$ and dealing with the stealership!
If not, you are out $4 for a pack of fuses and continue below...
Pull the drivers side door module switch and check the resistance of the switch.
POWER LOCK SWITCH
SWITCH POSITION RESISTANCE BETWEEN CONNECTOR C-1 PINS 7 & 11
NEUTRAL 10 KILOHMS ± 1%
LOCK 820 OHMS ± 5%
UNLOCK 330 OHMS ± 5%
04, Laramie 4x4 QCLB, Directionals in the Mirrors, Smarty SO6 POD, ISSPRO EGT/Boost/Tranny Temp, Quadzilla RP Gauge, Air horns, Boost Elbow, Airbox Mod, 2nd Gen intake, Diamond Eye 4" turbo back, Lost kitty "23 Years US Navy Chief"
Hypertech III for 2004 Dodge Ram Diesel for sale
iccmiller is offline
post #5 of 8 (permalink) Old 09-16-2009, 02:35 PM
Right now you cant manually lock the doors. The locks wont move up or down. Could they be froze up?
beebelawn is offline
post #6 of 8 (permalink) Old 09-16-2009, 03:01 PM
iccmiller's Avatar
If you can not manually lock any of the doors then you really have a problem and the motors are probably frozen up.
post #7 of 8 (permalink) Old 09-19-2009, 11:00 PM
Morfael's Avatar
I had to replace both of my back door actuators. They are a dealer only item, trust me, I tried.. My drivers side was out, ordered it from the dealer, by the time it came in my passenger side was acting up. Took me about an hour to replace both of them.
Morfael is offline
post #8 of 8 (permalink) Old 09-19-2009, 11:02 PM
Morfael's Avatar
Even if the motor is froze/bad you should still be able to manually lock them. Sounds like something else is wrong there.
Morfael is offline
