Old 11-06-2009, 02:22 AM   #25 (permalink)
2003 Ram, I noticed in your last pic the tie rod bolts to the bottom side of the pitman arm. Did the original set up have the tie rod bolted to the top of the pitman arm? On my 07 the tie rod is mounted on the top of the pitman arm, I like the bottom mount better and plan on changing to this new set up soon.
2007 3500 Mega Cab Larame 5.9 Auto, Custom CAI, 2 1/2" level kit, Cats missing, Quadzilla BF and Flowmonster muffler.
Smoksho is online now   Reply With Quote
Old 11-06-2009, 10:06 PM   #26 (permalink)
Laramie4x4's Avatar
Originally Posted by dom42 View Post
wait, so are you saying that the newer setup in the 1st post is a solid bar all the way across. because it doesn't look like it to me...........
...on the other hand , don's thuren's setup is a true solid tie rod.....
....is that what you meant.
new oem setup
don thurens
as you can see with the pic's its not a true solid set as far as the OEM setup vs don's....thurens is what you want.
wrong truck to compare it to.... and mags contact the track bar because the arms you have are garbage.. I went through the same problem...
Laramie4x4 is offline   Reply With Quote
Old 11-07-2009, 12:19 AM   #27 (permalink)
Cummins Diesel ADdict
dom42's Avatar
which arms are you refering to...the control arms???????? just curious...i need to address this issue.
2006 2500 QCLB 4x4 auto-5" SilverLine TBE - cfm plus- s&b CAI system- 6 inch superlift- kore components- 325/60/20 bfg AT's- 20" motometal- fs2500 on engine & tranny- maghytec all around- 4.10gears- BullyDog Pmt w/crazylarry- truckcoverusa roll out cover- rhino linings- firestone bags- Nfab 6step- Thuren trackbar
k7gsxr1000- full race bike- ohlins all around-brembo masters-full ti arata exh-pretty much everything
dom42 is offline   Reply With Quote
Old 11-07-2009, 12:52 AM   #28 (permalink)
Laramie4x4's Avatar
yes my crappy super garbage control arms... they give the same set for the 4" and 6" and puch the axel to far forward... causing the track bar to bind during up travel... I had to make a track bar with a wicked bend to clear the diff... then I decided instead of spending a 100 bucks on arms.. and I have built numerous rock crawlers...build my own....save 600 bucks.... same quality as thurens...which are awesome using the same parts...
Old 11-07-2009, 12:59 AM   #29 (permalink)
dom42's Avatar
do you think that the control arms i hav now can be adjusted to clear.????? i actually just noticed this issue last week before my truck went to paint(mat black).
how much would you charge for a set????
Old 11-07-2009, 01:30 AM   #30 (permalink)
Laramie4x4's Avatar
probably 600 hundred shipped and powder coated any color you want...
Old 11-07-2009, 01:38 AM   #31 (permalink)
dom42's Avatar
sweet, i will keep u in mind.....i get my truck back in a few weeks. will take it from there....
Old 11-07-2009, 02:24 AM   #32 (permalink)
Laramie4x4's Avatar
ok no worries.... I'm not going anywhere
Old 11-08-2009, 09:28 PM   #33 (permalink)
not greasable........
Just did this mod to my 05. The ARE greaseable.
ParrotHead is offline   Reply With Quote
Old 11-08-2009, 10:03 PM   #34 (permalink)
ok I'm going to do this mod next I just want to make sure what I need.
-Tie rod/drag link assembly with the nuts
-Pitman arm
-steering stabilizer
Is this correct? Any good place to get them from besides a dealer?
04.5 2500 4x4 qcsb sport laramie, Browns Diesel built 48re, BD flexplate, Mag-Hytec dd, Goerend triple disc, lock up switch, pxrb, fte resonator & hushpower, airdog II 165, Smarty Revo, Ride-Rite w/wireless controller, S&B elbow and CAI, 315s, B-quiet.
PatrickCj is offline   Reply With Quote
Old 11-09-2009, 01:10 AM   #35 (permalink)
moparonlineparts.com 52122362ae kit, 52122370ab damper, 68039930AA pitman arm
6502473---Bolt (1), to attach steering damper
6505623AA---Nuts (3), to attach new linkage
6502835---Nuts (2), to attach steering damper
It's where I ordered my stuff
Old 11-09-2009, 02:29 AM   #36 (permalink)
When I typed in the part number for the pitman arm it came up with this
Steering - Steering gear & linkage - Pitman arm Pitman arm, ram 1500 mega cab - power - conventional, 4wd (2008) 2008
I have an 04.5 2500 short bed will it work? It says its for a 1500 mega cab.
