Old 11-04-2009, 10:57 PM   #13 (permalink)
Originally Posted by dom42 View Post
where as the setup(1-52122362AE) in the 1st post shows a y axis setup similar to old setup. infact its the same setup just larger diameter on tie rods.
sorry but thats not what you want. and on top of that im pretty sure the newer set up is not re greasable......
Yes the crossover is sweet but if you look the new setup is a solid bar all the way across which is a way better setup. All the Carli guys run it and Thuren himself recommends it as he likes the setup.
2006 Mega SLT - Carli Starter - Carli trackbar - Fox SS - Magnaflow custom dual 4" - K&N Intake - Magtec tran pan rear diff. - PacBrake airbags - Moto Metal w/ 35x12.5x20 Toyo M/T - Smarty Jr.
titan0454 is offline   Reply With Quote
Old 11-05-2009, 12:12 AM   #14 (permalink)
Shagginwagon's Avatar
Does this new linkage work with mag-hytec front diff pans? Judging by by the looks it might be a problem.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is online now   Reply With Quote
Old 11-05-2009, 12:43 AM   #15 (permalink)
I would check to see if magtec has different cover for the 08.5 years and up as this is thier linkage.
Old 11-05-2009, 01:39 AM   #16 (permalink)
Cummins Diesel ADdict
dom42's Avatar
wait, so are you saying that the newer setup in the 1st post is a solid bar all the way across. because it doesn't look like it to me...........
...on the other hand , don's thuren's setup is a true solid tie rod.....
....is that what you meant.
new oem setup
don thurens
as you can see with the pic's its not a true solid set as far as the OEM setup vs don's....thurens is what you want.
2006 2500 QCLB 4x4 auto-5" SilverLine TBE - cfm plus- s&b CAI system- 6 inch superlift- kore components- 325/60/20 bfg AT's- 20" motometal- fs2500 on engine & tranny- maghytec all around- 4.10gears- BullyDog Pmt w/crazylarry- truckcoverusa roll out cover- rhino linings- firestone bags- Nfab 6step- Thuren trackbar
k7gsxr1000- full race bike- ohlins all around-brembo masters-full ti arata exh-pretty much everything
dom42 is offline   Reply With Quote
Old 11-05-2009, 01:46 AM   #17 (permalink)
dom42's Avatar
New OEM setup has four connecting points and dons only has three....
Old 11-05-2009, 06:13 AM   #18 (permalink)
Having installed this myself I can positively confirm that the lower bar is a solid bar all the way across with the tie rods at each end. The old setup had the tie rod ends on two different bars. Look closely at the first post and you will see the difference, there is a reason why everyone is changing to this as well as why Dodge made the change in the first place.
mjf6175 is offline   Reply With Quote
Old 11-05-2009, 12:40 PM   #19 (permalink)
bd797's Avatar
Are the joints on the 09 setup greasable or is it as worthless as the original setup?
05 3500 QC 4WD, G56, Custom Intake, Jacobs Exhaust Brake, Amsoil Dual Remote Filters, Prodigy Brake Control, Muffler and Cat Delete, Custom Flatbed and B&W
bd797 is offline   Reply With Quote
Old 11-05-2009, 02:18 PM   #20 (permalink)
j_purkey07's Avatar
subscribing
2005 4x4, southbend 3600 DD, Edge Juice with attitude/W hot code, MP-8, S&B intake and intake manifold, 5 inch turbo back straight pipe, Air dog 150, 90hp injectors, Rail cap, Quad F/RPG... Super B Special, Arson III and water/meth soon to come!
j_purkey07 is offline   Reply With Quote
Old 11-05-2009, 05:39 PM   #21 (permalink)
dom42's Avatar
not greasable........
Old 11-05-2009, 05:42 PM   #22 (permalink)
Dom,
Do you have a MH front diff cover? I see in your sig you do. If so, no problems with the Thuren track bar and the MH diff?
Thanks
IAFF Local 1159
Old 11-05-2009, 05:56 PM   #23 (permalink)
dom42's Avatar
Originally Posted by Shagginwagon View Post
Dom,
Thanks
you know what, it did kinda scuff it up. i took it out to pismo beach and practically lauched the front end and bottom'd out pretty good. The cover made contact w/ thurens track bar and i even have a 6'' lift.... but its held up pretty good. definately still better then the stock.
Old 11-05-2009, 11:49 PM   #24 (permalink)
What he said!
