| 3rd Gen. Non-Powertrain Discussion of 3rd Gen Topics Not related to the Powertrain...NO ADVERTISING |
#13 (permalink) |
nevermind re-read of your egt install
2004 Dodge Ram 2500 QC LB H.O. (305 HP) CFM + intake manifold, 4inch Silverline Turbo Back Exhaust, AEM Brute Force HD Intake system, ISSPRO Gauges (Boost, Pyro, Trans), Custom grill inserts, Recon smoked cab lights, Predator Power Puck |
#14 (permalink) |
subscribing nice write up
06 2500 mega cab white leveled with 35" dick cepeck fcII smoked cab lights B/W pocket style flares super chips flash pack. Southbend dd, air dog 150, 5" straight pipe and willys wistler http://www.cumminsforum.com/forum/kentucky/ |
#15 (permalink) |
Very nice writeup, i smell a sticky!
2008 Laramie "Speed costs money, How fast can you Afford to go?" Performance Shops I Prefer, www.rollinsmokediesel.com / www.k2dieselperformance.com / www.genosgarage.com |
#16 (permalink) |
Nice work man, Thanks for teh write up. I just installed my Boost gauge today, waiting for the trans temp adapter to put the probe in the test port on the tranny, then I have 4 more gauges to go in. I never actually took my light switch out, the only thing I had to remove was the side panel, then I could easily see the wires.
2006 3500 Mega Cab Laramie, 4x4, 3.73, Smarty POD, AFE SII CAI, CFM+, QZ BoostFooler, HIDs, 5x Isspro EV2s, frnt EBC drilled/dimpled rotors w/ greenstuff pads, KW DNX9140,Viper 5901... |
#17 (permalink) |
What's the little silver round connector thing at the bottom of the pillar?
04 2500 HD, Reg Cab, 4x4, 305/555, NV5600. 5" SS Silverline, Smarty, Isspro, PSC Steering Brace, AD 150, SB 3600 DD, Arson II
402/888 |
#18 (permalink) |
Thats the dimmer knob for the gauges. With the isspro wiring harness, the gauges will dim or brighten with the dash, but that knob allows you to fine tune the gauge brightness to match the dash. I just left mine hidden under the dash where I can still reach it
#19 (permalink) |
Thanks, I'm needing that little sucker, and the new programming. My rp gauge is an ev2 while the rest of them are just ev's. Need to get rid of that flicker and get it to match.
402/888 |
#20 (permalink) | |
2006 Dodge Ram 2500 QC/SB Big Horn Edition Quadzilla Xzillaraider 2 Race Module, 5" Turbo Back Exhaust, BHAF, Leveling Kit w/ 35's, ISSPRO EV2's-Pyrometer, Boost, Trans. Temp. |
#21 (permalink) |
Nope, I haven't converted them. But I did know just to hook it to the ev2 gauge
402/888 |
#22 (permalink) |
![]() Join Date: Oct 2008
got my gps in the same exact spot, stuck in the corner
2004.5 2500 Long bed Reg Cab A/R Teflon Coated Rims,Wrapped in 33" Hankook M/T's,BHAF,smarty,Ts Performance Ramifier 100hp Pressure Box.4 inch exhaust Rat Rod style. Autometer boost,egt,tranny.Isspro fuel pressure.w6. Valve body,input shaft,T/C stb. |
#23 (permalink) |
did you use a boost bolt?
03 quad cab, 4x4, long bed, st, leveled on 35 12.50 17 toyo m/ts, nv5600, 165,000 miles, got it for $9000 had the t case rebuilt for $726 and put $1400 of tires under it. 75 horse injectors silencer ring mia http://s619.photobucket.com/albums/tt275/leveled03/
#24 (permalink) |
Sure did. I suppose I should finish my post and put up the rest of the pictures.
