does this look normal? (suspension parts) - Dodge Cummins Diesel Forum
Old 06-18-2009, 03:53 PM   #1 (permalink)
Driver
Passenger
2006 2500 5.9 Quad Cab | ATS Tranny | CAI | Pusher Intake Horn | FASS Fuel Pump | Straight Pipe | Pure Auto Parts
eHaze is offline   Reply With Quote
Old 06-18-2009, 04:01 PM   #2 (permalink)
dillonjm's Avatar
Both links look a little rough. The top bolts look loose and one has a torn boot. I'd consider replacing both. They are called sway bar links
08 2500 Laramie QCLB 6.7L G56 4x4 (DD/Toy Hauler):
DPF/EGR/Cooler Deleted, 5" Flo pro w/Aero 5050xl + FTE Resonator, Smarty, SB 3250 DD, ARPs, 3.5" TGC, 285 75/18 Toyo AT2 on Pro Comp 1069s
dillonjm is offline   Reply With Quote
Old 06-18-2009, 04:08 PM   #3 (permalink)
should they be straight?
the one on the driver side appears to bent above the top bushings.
Old 06-18-2009, 04:12 PM   #4 (permalink)
cutworm's Avatar
I had a 2" lift on mine and my sway bar lings ended up looking like yours. I went to Gen's Garage (a vendor on this site) and ordered mine. They are called MAXX LINKS SWAY BAR LINKS, around $90 & install easy.
'99 Dodge 3500 4X4 Dually, 5 spd, powerpuck, Airdog 150. That's all for now...
Had to sell the '06, too many transmission problems. Apparently 1600 ft/lbs of torque was too much for an automatic!
cutworm is offline   Reply With Quote
Old 06-18-2009, 04:13 PM   #5 (permalink)
07Bighorn's Avatar
Yes they should be straight... Do you ahve a lift or a leveling kit? when I leveled my truck within 20mile both bent, I replaced them with a set from Lorenz, but there are alot of companies that make upgraded Sway bar end links,..
07 Dodge 2500 Big Horn 5.9L... AFe Stage2 Cx Pro Dry S, WinSpeed heater delete, MRBP cat delete.... Quad boost Fooler 296.7hp baseline. 2" leveling kit with Ion 133 wheels wrapped with 35" Nitto's and wants a playmate for my stock turbo!
07Bighorn is offline   Reply With Quote
Old 06-18-2009, 05:38 PM   #6 (permalink)
not exactly sure what lift is on the truck, but there is a lift of 6"+.
