Spare Tire Mount In The Bed - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-14-2009, 04:57 PM Thread Starter
D45
D45's Avatar
iTrader Score: 16 reviews
Due to some recent mods, I had to push the 5" MBRP exhaust back abound 2".
By doing so, I had to completely remove the spare tire that was mounted in the stock location, under the bed.....not much good the stock LT265 tire would do me anyways, oh well
So, I want to find a used 37" tire and mount it in the bed, someway.....somehow
I remember they used to make a clamp for the bed rails, which had a few automotive stlye studs that would securely mount a spare tire. Does anyone know what I am talking about or where I can find such a mount?
Or, are there any other options I might look in, that will not take up huge amounts of space.....I was hoping to mount it on the front passenger side of the bed, infront of the wheel well area:
I bought a 6' pieice of a Masterlock 1/2", rubber coated cable to lock the spare up with. Plus, I have a cap covering the bed, that is also always locked
Lastly, does anyone know what width the stock spare wheel is and if I can mount a 37x12.50 R17 tire onto it?
Thanks for any and all info!
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
D45 is offline
post #2 of 6 (permalink) Old 06-14-2009, 05:09 PM
CummewfwnsSoer04's Avatar
just look at some aftermarket spare tire carriers and make something useable out of that. i mean thats kinda what i do, look at something thats already been made and say i can build that
2004 Dodge Ram 2500 QC LB H.O. (305 HP) CFM intake manifold, 4 inch Silverline Turbo Back Exhaust, AEM Brute Force HD Intake system, ISSPRO Gauges (Boost, Pyro, Trans), Custom grill inserts, Recon smoked cab lights
CummewfwnsSoer04 is offline
post #3 of 6 (permalink) Old 06-14-2009, 06:04 PM
CM_CUMMINS's Avatar
Well since you have a shell on the truck you couldnt look at the tire gate option. But if you have a welder of know a buddy that does you could fab up pretty much exactly what you are looking for. Coat it with bed liner and bolt it in. I know there are some companies that make spare tire holders that bolt into your bed but i haven't seen one that mounts it to the side but they could be out there!
2006 QCSB
Mineral grey
CM_CUMMINS is offline
post #4 of 6 (permalink) Old 06-14-2009, 08:34 PM
5alive's Avatar
Something like this Valley Industries In-Bed Spare Tire Carrier | Cargo Haulers + Ladder Racks | Northern Tool + Equipment
2005 SLT Reg Cab DRW 4X4 48RE
5alive is offline
post #5 of 6 (permalink) Old 06-15-2009, 11:34 AM Thread Starter
D45
D45's Avatar
That looks good, but it says:
"Can be used with 14in. to 16.5in. wheels with a 7in. max. rim width"
I would be using a 17" wheel that is 8-8.5" wide
D45 is offline
post #6 of 6 (permalink) Old 06-15-2009, 11:39 AM
tryNto's Avatar
get a piece of flat steel from a parts place that sells welding supplies, also a piece of all thread...
make your own...
2003 QCLB 2500 HO NV+Fast Coolers 3.73 4x4,
Edge CTS Evo W/Bunch of Gauges, Donaldson DBL7349 Oil Filter, Baldwin PF7977 Fuel Filter, GDP kit W/Donaldson P551313 FF, OEM Fan Clutch Delete, Steering Box Brace
tryNto is offline
