Way to Drain Fuel Tank - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 06-11-2009, 06:54 PM Thread Starter
hoytarchery7's Avatar
does anyone know of a way to drain the fuel tank. there is a white thing on the bottom of my fuel tank that looks like a "U" will that drain it or is there another way. we tried syphening it out and i guess they were made so it cant be done.
hoytarchery7 is offline
post #2 of 14 (permalink) Old 06-11-2009, 07:07 PM
DNCII's Avatar
Easy,
1) Start the Truck and let it warm up a bit (never drain fuel when the motor is cold!!!)
2) Find a LEVEL piece of concrete or asphalt
3) With the truck in gear (automatic), stand on the brake pedal and apply throttle until the wheels start to spin.
4) Continue to hold brake pedal and regulate throttle until engine runs out of fuel.
5) tank is now empty.
2006 Ram Patriot Blue 4X4 QC SRW LB CTD
DNCII is offline
post #3 of 14 (permalink) Old 06-11-2009, 07:11 PM Thread Starter
Originally Posted by DNCII View Post
Easy,
hahaha yea that would work and i have new tires to put on it. but seriously is there a way to drain it?
post #4 of 14 (permalink) Old 06-11-2009, 07:26 PM
Banned
Fill it up with gas? I don't know how to do it on your truck but search for and read through some threads where people put gas in the tank and see if they said how they drained the tank.
JDiepstra is offline
post #5 of 14 (permalink) Old 06-11-2009, 07:31 PM Thread Starter
no it doesnt have gas but it has bad fuel there is water in it and the truck wont run right. i would take it back to the place i just filled it at but thats if the truck would even make it there and they probably wouldnt do anything anyhow. oh i just noticed i posted this in the 3rd gen. section dont know why i did that.
post #6 of 14 (permalink) Old 06-12-2009, 04:46 PM
Hank60's Avatar
put a hole in the bottom....atleast a .45 caliber....that pught to drain it fairly quick haha.. but seriously...pull your fill neck off and you should be able to siphon from there...
i would actually siphon the tank then pull it out to make sure you get it clean and dry on the inside....water reeks havic on the fuel system... good luck
'09 QCSB 4x4 bone stock farm truck, recon strobes, boss 9'2" vxt
'96 12v soon to look like a Chevy
Hank60 is offline
post #7 of 14 (permalink) Old 06-12-2009, 05:05 PM
cumminshakesit's Avatar
X's 2, i did that on my moms 02 after she filled it up with gasoline... i used a small jabsco and some garden hose. good luck. you should let that place know they are selling bad fuel? they may also compensate you for it...
2K6 mega cab, 6 spd handshaker, 6" BDS Long Arm, South Bend SDD3250, 5" flo-pro, Smarty jr, 17x9 Fuel Maverick's on 37x13.50 Toyo MT's SAC #257 DTR MEGACAB CLUB #207
cumminshakesit is offline
post #8 of 14 (permalink) Old 06-12-2009, 05:18 PM
Substation Operator
speed185187's Avatar
iTrader Score: 5 reviews
i drained mine to install the 1/2" pickup by hooking up a pump to the line coming from the tank to the fuel filter. You could also use the stock lift pump by unplugging it and applying 12V from the battery.
There are lots of ways to drain the tank.
16 Chevy 3500 CCLB Dually LML
14 K1600GTL-E
03 Jetta GL TDI platinum grey (summer driver)
03 Jetta GL TDI reflex silver (project car)
13 C-Max Energi (hers)
speed185187 is offline
post #9 of 14 (permalink) Old 06-12-2009, 06:19 PM Thread Starter
now it seems like it doesnt want to start by its self we have to give it a little gas and it will start right off and run fine. but it just needs a little gas and it will start. my dad said its like its loosing its prime somewhere. like fuel isnt getting to it until we give it a little gas and it starts. i said about it might be an injector but he said it wouldnt run right at all if that was the problem. someone said the idle might be too low, how do i adjust it? thanks
post #10 of 14 (permalink) Old 01-21-2011, 12:33 PM
how about if it has 10 gallons of premium, unleaded in the tank?
Easy,
6) How would you drain the tank if there was about 10 gallons of premium gas in the tank?
phoneranger1 is offline
post #11 of 14 (permalink) Old 01-21-2011, 01:40 PM
cgmorgan06's Avatar
iTrader Score: 61 reviews
Drill a hole in the botton let it all run out, then put a screw with a rubber washer in the hole to seal it. Dont ask me how I know this works.
Grant
'06 black mega laramie 3500 srw 4x4, fully loaded, 6" superlift, 37" trail graps/22" M81s, AMP steps, true 5" custom duals w/7" tips, Autometers, ATS Stage 6 48re, II 85%, JL 150's, 62/480, HD push rods/springs, Spool Aid/GDP Air Boss/Grid Delete/ATS Arcflow, Airdog II, Amsoil bypass, Wicked coolant bypass, GDP Ladder Bars, Viair dual 480C, Nathan K3LA, Kenwood DNX 9140, JL 10's
560hp/1268tq 4/30/11
cgmorgan06 is offline
post #12 of 14 (permalink) Old 01-21-2011, 08:16 PM
tdrive0001's Avatar
the guy i got mine from had put about half a tank of gas instead of diesel in mine. i ran a 1/2 inch hose into the neck, and worked it into the bottom of the tank. drew out the bad fuel and filled mine up with ol' #2 and a full bottle of power service. did this twice and no problems yet...
06 5.9 QCSB 4X4, Fuel mods: Big Foot, Air Mods: silencer ring tossed, Exhaust Mods: straight pipe from turbo to bumper. Looking for free HP
tdrive0001 is offline
