| 3rd Gen. Non-Powertrain Discussion of 3rd Gen Topics Not related to the Powertrain...NO ADVERTISING |
#37 (permalink) |
Location: Oahu, Hawaii for now (can't wait to get back to the mainland)
You need the offset pipe as well. Your stock muffler has an offset inlet and outlet, and the Aero is straight. There is a drop down option on the Parley's website for the offset pipe.
2007 2500, QCSB, 4x4, 5.9L, 48RE, silencer ring MIA, torque tube baffle MIA, B&W Hitch, Smarty Jr POD, Isspro gauges (boost, trans temp, EGT), Aero Turbine 4040XL, smoked cablights |
#38 (permalink) |
Mine should be here (4040XL) in the next day or two-I also ordered from Parley's. I may add-can't beat their price either ! My truck is currently straight pipe-no cat/muff delete-I'm wondering if I'll need anything else to get the job done....guess I'll find out when it gets here.
06 mega cab Laramie 4x4, 5.9, 37x12.50 pro comp extreme mud terrains, 20"rims, bilstiens, no cat-muff |
#39 (permalink) | |
![]() Join Date: Dec 2007
Thanks...Are you happy with the sound and performance?
2006 2wd 2500 - CFM intake - Amsoil oil bypass -Aero 4040XL Muffler - K&N Air - Cool Blue Hose - Delvac Rotella oil, everything else Amsoil - Alpin 505 / Blackbird nav / XM (XM 202 Sirius 197 - O&A RnF) , Optilube Summer blend Future: Coolant Filter, External tranny filter |
#40 (permalink) |
Shup1..... I love the sound of mine. Performance wise, there is no gain or anything that I can tell. Supposidly there is supposed to be an MPG gain. After one tank, I jumped .8 MPG. But that is only one tank. Take it for what it's worth. Red1..... The inlet side of my 4040XL didn't fit over the 4" pipe, but the outlet did. So what I did (since I'm too cheap to pay expensive Hawaii shop rates) was I went to Napa and got a 4" strap clamp and used that. It was like $15. It's not 100% sealed but it's way cheaper than paying some one to do it.
#41 (permalink) | |
98.5 24V ext cab long bed laramie, comp box,ats trans, afe 2, hx35, Autometer gauges, 01 24V ext cab, short bed, 4x4, silver sport, NV4500, 15% tint, 4" str8 pipe, k&N, leveled, 35's, eagle alloys |
#42 (permalink) |
That's good news.
#43 (permalink) |
i have an 05 no cat and 4040xl in mostly stock location with little to no drone at highways speeds. I am very happy with it. That being said I think that drone also has alot to do with where the muffler is mounted. if its under the cab you'll get more drone than next to the rear axle. Aero recommends at least 12" past the outlet before any bends in pipe for best profomance/mpg. I like mine, people deffinately know when I am taking off but at normal cruising speeds they don't pay much attention to it driving or passing them. usmc5593 |
#44 (permalink) | |
Thanks
#45 (permalink) |
Just installed my 4040xl. Obviously on the 03's and early 04's, some fab work has to be done to get them in since our stock pipes are only 3.5" to the muffler and 4" muffler back. If it helps anyone, I ended up getting 2 45* bend 3.5" Elbows and a 4"->3.5" adapter. Had to shorten the elbows a little bit with my chop saw, but it ended up working perfectly to account for the higher outlet of the factory muffler. (I added the rise before the muffler instead of after) For what its worth, it has a great sound, almost not even noticible at highway speeds unloaded @ 70, in those conditions its stock levels in the cab. However, it is pretty loud from about 45-55, but I could hear my stock exhaust drone a little @ those speeds too(right as the TC locks up and RPM drop to around 1500). Its not annoying by any means, it sounds great. I'm very happy with mine. I didn't want an obnoxious exhaust and this definitely isn't obnoxious. I'd even venture to say the 01 1500 I used to own with a 360, high flow cat and Flowmaster 50 is louder (in cab) at highway speeds. On accel, the 4040 has it beat though for noise levels. (I know its apples to oranges, but it might help someone whos familiar with gas engines understand)
03 Silver Quad Cab/Short Box 2500 305/555 4x4 - 4040XL - 2" Lift - 285 75R17 Dura Grapplers Last edited by dillonjm : 07-20-2009 at 10:34 AM. |
#46 (permalink) | |
#47 (permalink) |
i have one under mine i dont remember if it is the 4040 ir the 4040xl it is quiet in the back of the stock location and just add pipe from there up to the front of the cat. how can you tell if it is the XL with out takeing it off?
comma to da top 05 cat mia, aero, smarty, blacked out and needs a sundial to be timed. Poser club member #2 ![]()
#48 (permalink) |
Have had 4040xl for about 8 months. Difference in drone if cat removed. Had about 4 months before removing cat. No difference at highway speed, but more drone while accellerating with cat off. However, removal of cat made greatest difference in seat of the pants feel.
04.5 2500 quad cab; 2wd; 48RE; aeroturbine muffler; cat MIA; S&B CAI; CFM+ intake; Quadzilla Max Milage: 83 FXR; 95 FLH trike; 06 street bob |
