New problem.... Air Bag light staying on - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 04-30-2009, 02:24 PM Thread Starter
Cookie's Avatar
Angry New problem.... Air Bag light staying on
OK we changed the TIPM reset the ABS light because it was on now the airbag light stays on.
I unhooked both batteries and waited 5 minutes for it to reset itself and that didn't help.
Clues anyone?
Please don't tell me it is the module for the airbags that has gone out, stealership says they cannot reset it, the book says to change fuse #'s 52 and 53, uhhhhh the panel only goes up to 41.
I have had this truck for 3 years and have never known of another fuse panel, if there is one it must be under the truck because it is not inside or under the hood.
2006 3500 Mega Cab 6 speed manual tranny 6 cyl 5.9L diesel
I call it my "Cowgirls Limo"
Cookie is offline
post #2 of 22 (permalink) Old 05-01-2009, 01:16 AM Thread Starter
Cookie's Avatar
bumping for answers
Cookie is offline
post #3 of 22 (permalink) Old 05-01-2009, 03:05 PM
Robert Ivey
Rivey's Avatar
iTrader Score: 5 reviews
ABS is the anti-lock braking system
08|QCSB|6.7|68RFE|4x4|513 rwhp
08|RCSB|6.7|48RE|4x4|1155 rwhp
06|RCLB|5.9|48RE|4x4|
rwhp
Built & Tuned by me @ Calibrated Addiction
Rivey is offline
post #4 of 22 (permalink) Old 05-01-2009, 11:25 PM Thread Starter
Cookie's Avatar
I said AIR BAG LIGHT not ABS is staying on now
The ABS light WAS on but they reset it and it went off now the AIR BAG LIGHT is staying on
Cookie is offline
post #5 of 22 (permalink) Old 05-06-2009, 11:03 AM Thread Starter
Cookie's Avatar
OK, the stealership wins, I guess I will have to take it there to figure out this problem and the erratic RPMs
Thanks for the suggestions
Cookie is offline
post #6 of 22 (permalink) Old 05-06-2009, 12:26 PM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
Since you just changed TIPMs, try fuses 20 and 21. both are 10amp fuses.
There are a number of things that goes into the airbag system. It could be the clock spring in the steering column, an airbag squib (checking for continuity), seatbelt pretensioner, seat track position sensor or an impact sensor, but you'll need to find what the code is first.
Check those 2 fuses first though with having just changed TIPMs
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
post #7 of 22 (permalink) Old 05-06-2009, 01:13 PM
HOBrian's Avatar
x2 on the clock spring.
2003 305/555 NV5600 QC SB Sport: Bed rug, sportsmasters TC, RS9000X, seat heaters, boost,pyro,FP on A-pillar, Quadzilla, Amsoiled
HOBrian is offline
post #8 of 22 (permalink) Old 05-07-2009, 11:40 AM Thread Starter
Cookie's Avatar
OK the clock spring is a new one on me, explain please
Cookie is offline
post #9 of 22 (permalink) Old 05-07-2009, 12:07 PM
The clock spring is what allows electrical signals to go through the steering column and still allow the wheel to turn.
You take a look at those fuses? It might say spare or something completely unrelated on the cover in the list, so look at the numbers. Also, double check the pins on the connectors and that all the connectors are seated fully under the TIPM.
John
post #10 of 22 (permalink) Old 05-07-2009, 11:38 PM Thread Starter
Cookie's Avatar
I am getting dizzy, I sure wish I would stop getting switched from forum to forum
Cookie is offline
post #11 of 22 (permalink) Old 05-07-2009, 11:40 PM Thread Starter
Cookie's Avatar
After what I went through with that dang thing, I will take it to someone else and let then fool with all those wires that confused the heck out of me LOL. I will check the fuses tomorrow morning.
Cookie is offline
post #12 of 22 (permalink) Old 06-07-2009, 08:10 PM
mayhemryder's Avatar
im having the same problems with my truck. i just put oem fog lights in mine and it started after that..but did u have any fuses bad
mayhemryder is offline
