hey guys, just wondering around what temp you pyro sits at in the winter, after start up..and how long it takes to warm up to max...and also in summer...or if its much of a diff..thanx for info..G in Canada
2004 2500 4X4 Mag-Hytec Tranny Pan, Frantz TP Filter, Coolant Filter, MBRP 4" TBE with FTE Resonator, Raptor100 with WS and 2 Mic Filter also in box, XRF Ball Joints and All 4 Tie Rods
IAFF LOCAL 142
(Professional Firefighter)
Not sure on the difference in 12v to 24v on EGTs but mine usually started up around 200F ish soon after start up in the winter and took maybe 30-60seconds to get to 250F ish... which is normal idle temps when still cold. In the summer it just warms up a bit quicker... only need to make sure to let her cool down to 250F-300F before shutting down to safe the turbo.
'98 2500, C/C, S/B, 12v, 5spd, 4x4, CAI, TST #12/BoostElbow, 4kGSK, +40hp Injectors, Turbo Diesel HP Intake Horn, BD Exhaust Manifold, AutoMeter Gauges, Bullydog 4" TB Straight Pipe, AR Outlaw IIs with Nitto Terra Grapplers, BD 3rd Gen Track Bar, BD Steering Box Stabilizer, and V-LEDs lights.
'08 International Durastar 4400, Fassi F170 Knuckle Picker, 12' flat deck; '79 Chevy C10 R/C, L/B, 350-4bbl, 3spd auto; '13 Dodge Dart SXT, 1.4L Turbo, 6spd www.stupidproductions.ca
hi, well i plugged mine in most of the time, noticed that if i let either the 2000 or the 2006 idle the engine would cool off and start with the white smoke. i just carefully accelerated until the ps stopped screaming so much and would turn the wheels,then take off slowly at first ,, i too chicken to mat it my egt's would be down off the bottom of the gauge(30F) until i get a mile down the road, then would climb slowly, noticed that driving in bad weather, -30kms/hour in a 100 zone,, it would get so cold that would be off the bottom again, shifting down did not show more heat(have covered rad) have had to wear parka this winter a few times. (new CUMMINS thermostat)
I always plugged in as well, and if I let it idle for more than a few minutes it was high idled right around 1000 or 1100 rpms. Otherwise I held it around 1100rpms for a bit then drove nice and easy, but I usually just did very short drives from home to the shop... by time I got to my destination I was getting some heat from the vents lol.
Previous owner or someone before that even rigged up a little pull lever hooked to a chain hooked to the pedal. Haven't really looked that close at the set-up, but just pull the lever out... holds a steady rpm.
