I'm going to be removing my stock muffler and cat but I have a question about the alignment of the stock downpipe and tailpipe.
If you remove the stock muffler and cat, does the stock downpipe and tailpipe align so you can install a staight thru muffler without using any special bend piece(s)?
I was looking at the downpipe and tailpipe and it doesn't seem like they line up correctly to be able to do that.
If there is a special part, where is the best place to get it?
'04.5 2500 QC, SB, SLT, auto, 4x4, 3.73
41" Donaldson w/CAT MIA & 5" custom tip, 2nd gen intake horn, smoked RECON cab lights, SRT-10 pillar pod w/Dipricol pyro, PML tranny pan, XRF & Precision parts
It will work but if you simply install a long piece of straight pipe then the only issue, if you consider it an issue, is that the angle of the exhaust tip will change. I did it on my 03 with no problems. Genosgarage.com sells a muffler delete pipe with the bends in it if you are concerned though.....
04 Ram 2500,Green/Silver 305/555HO,48RE,3:73s,QC,LB,4x4,Roadwire Leather Seats,Laramie Interior,Infinity Sound,HE351 Turbo,Custom 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan+180 Stat,Fogzilla,TRM,BFG AT 305/65s,72,000 miles
Yah, a muffler delete will work if the bends are fairly close together. I got 2 45's and got them welded together to make the offset so the tail pipe didn't change:
Cat is still in, 40" Nelson muffler.
