charging trouble - Dodge Cummins Diesel Forum
Old 03-19-2009, 10:15 PM   #1 (permalink)
cummins6by6's Avatar
charging trouble
Hi there new to this. Im having a major problem with what seems to be my charging system. I have a 2004 cummins,6spd. My volt gauge seems to dive down to 0,then the check gauges light comes on.I have replaced both batteries and the alternator.The reason i replaced both batts is that they had both basically boiled over.I had the alt checked,was told to replace it.So replaced batts and alt. worked good for 2 days,now today it did the same thing,alternator was to hot to touch, i shut truck off in order to save batts and hopefully the alt.2 codes come up , they are (1) charging system output voltage, (2) battery temperature sensor performance. Any kinda help would be great . I live 300miles from the nearest dodge dealer,so trying to figure this out.Thanx Cummins6by6
cummins6by6 is offline   Reply With Quote
Old 03-19-2009, 10:22 PM   #2 (permalink)
TECH SPECIALIST
underramarmor's Avatar
turn your truck on... and test with a meter what is the voltage... it should be damn near 14 vdc if not alil more....
check the wire goin from the alt to the battery make sure that the POS wire its hitting the frame or any part of the block (just alil advice)
2004 Silver Srt 4 Stock
2005 Black Ram 2500 5.9l 2wd Auto
2007 Blue Ram 2500 6.7l 4wd Auto
underramarmor is offline   Reply With Quote
Old 04-27-2009, 05:55 PM   #3 (permalink)
Issue resolved? I'm having the exact same problem with my 03.
2011 3500 Crew Dually Laramie G56
Read More, post less.
CMNS PWR is offline   Reply With Quote
Old 04-27-2009, 07:41 PM   #4 (permalink)
VAautotech's Avatar
chrysler loves those Nippo alternators and to regulate them with the ecm. My guess would be the charge regulating circuit of the ecm is bad. Start vehicle and ckeck with a good meter. If its 15V or over, thats the problem.
2008 Dodge Ram 2500 Mega Cab, 4x4, nav, alpine headrest monitors, Clarion DVD, Line-Xtra, Banks ram-air w/scoop, amp research power steps, HID fog lights, deletes up soon.......
VAautotech is offline   Reply With Quote
Old 04-27-2009, 07:55 PM   #5 (permalink)
grid heater relay
Also check to grid heater relay. this same thing happened to me 2 times this winter, the relay got stuck closed and was drawing to much current. maybe not the cure but something to look at.
2005 Dodge Ram 2500 CTD 5.9L H.O.-4wd-Quad Cab-Edge Juice W/Attitude Hot Unlocked W/ Turbo Timer,DTT Trans, 50Hp injectors, Amsoil BMK11, PSC Steering Brace, Ice Box CAI, Bilstein 5100 Shocks
boozzer86 is offline   Reply With Quote
