I just replaced my rear drive shaft's rear U joint and Just replaced the Front outer U joints. I have checked the front drive shaft U joint and they are good. But I have a vibration when I drive down the road. It gets more noticable the faster I drive. I checked the weights on my rims and there all there. Any idea's
06/6spd/yadda dadda da
EFI LIVE
No data received
Unable to load the webpage because the server sent no data.
do a search for 3rd gen vibration. tends to be common. i won't even tell you how much i've spent to find it. could be as simple as your skid plate or an exhaust hanger
__________________ FTE Diesel - Redline Diesel Power - Floor It Diesel
The ujoints in the CV joint in my frint driveshaft went bad and caused a similar vibration as yours, I kept checking it and it looked fine, until I finally pulled it and drove it and the vibration was gone, you might try pulling your front driveshaft and then test drive it just to be sure.
The road goes on forever and the party never ends
I was doing some googling and read somthing that said if there is fluid around an opening then you might have a bad bearing. So I went out to the truck and check my rear axle, and around the yoke going into the pumkin has some residue. Could I have ruined that bearing. The night my rear u joint started vibratin I had to drive about 400 miles home then I replaced the rear drive shafts rear U joint the next day.
EFI LIVE
No data received
Well when I get home I will drop the front drive shaft and take it for a spin. Then I might drop the rear drive shaft and take it for a spin. UNLESS SOMEONE SAYS THE REAR DRIVE SHAFT DROP AND DRIVE IS A BAD IDEA.
EFI LIVE
No data received
Bad idea... you will loose transfer case fluid... but I'm pretty sure you were joking.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
