Help! Need and additional FUSE Block. - Dodge Cummins Diesel Forum
Old 03-16-2009, 03:36 PM   #1 (permalink)
Ashtiani's Avatar
Hey guys, Anybody install an additional (accessory) Fuseblock under the hood? Any advice on brands? I have too many aftermarket electrical accessories connected to the POS+ side of the battery and too many fuse taps! I would like to clean things up under the hood. I would prefer to install a weather resistant one under the hood if possible. Thanks for your input.
Ashtiani is offline   Reply With Quote
Old 03-16-2009, 04:10 PM   #2 (permalink)
TBittner's Avatar
i think genos sells one
2012 Mega 3500 4x4 G56 3.42 Laramie- Deleted
2005 QCSB 2500 4x4 Auto- stock
TBittner is offline   Reply With Quote
Old 03-16-2009, 05:55 PM   #3 (permalink)
i would suggest a basic fuse block. BoatFix.com :: OnLine Store
all you have to do is run a 12v+ to the block.
as far as your negative side of the battery, with DC 12V you only have to have a common ground(normally the frame of the vehicle is a great place to ground wires, so attaching the ground to the battery is a bit excessive. so just attach your ground wire to a piece of metal connected to the frame
2002 Ram 2500 - 4x4 NV5600 - 4" MBRP Turbo Back w/ AFE Resonator and Hushpower Muffler - 1/2" Fuel system w/ Draw Straw - FASS DDRP 100 w/ Big Spring(17-18psi IDLE, 14-15psi WOT) - Borgeson Steering Box w/ Borgeson Shaft - DOR Steering Brace (on the way!)
smokin_dodge is offline   Reply With Quote
Old 03-21-2009, 11:40 PM   #4 (permalink)
This is what i just got done installing on my truck for my gauges. Plus there is still plenty of room for other items that i might install later. I did buy the 12 position with ground, made a bracket and installed in the engine comp. right behind the drivers side battery. Looks professional and room to grow. I different prices online but went to the local marine supply and they had it for about the same price. The one below is at West Marine: Home Page
6-Position Fuse Block with Ground, 3.315"W x 5.23"L x 1.518"H from BLUE SEA SYSTEMS
Clear insulating cover insulates all conductive parts meeting ABYC/USCG requirements, and color-coding makes determining amperage easy. Tin-plated copper buses and fuse clips give 30A per circuit. Accepts ATO and ATC fast acting blade type fuses and plug-in style circuit breakers. Max. 100A@32V DC. Write-on labels included.
1khakimegacab is offline   Reply With Quote
