I did what alot of people did to lower my truck, yanked out the overload spring, and relocated the blocks to on-top of the remaining springs. But its not quite level enough for me.. Has anyone installed a lowering kit on their truck? I only wanna bring the rear down about 3 inches, that should put it about level with the front. Any help would be great. Thanks guys
2011 Crew Cab 4x4 - Gonna keep it stock and ride the warranty for a while.
I took all the springs out of my truck except the main leaf and the flat one. then put an air bag in....i have wheel hop and my axle isnt at the right angle.....need to be adjusted with spring shims and to solve the wheel hop/axle wrap im going to put trac arms in. If you want more info on what i did pm me
99 3500 DRW 2wd QC, TST Comp, SmartyRevo, Silver 64,DDP 220-230, holley black, 4"dp 6" from dp back to stack, ARP studs,O-ringed, trans goerend tq & input, Storm Block 12.3@109.95 on broken limited slip http://youtu.be/ez13avzx3mc
On my mega I didnt have the spacers under the spring pack and I dont want to take out the overload on the bottom of the pack either.
Im working on getting a set of shackles that will drop the rear 1.25" and 2.5"s, ill post some pics soon...
Im tired of the back end sitting 5-6"s higher than the front:p
'12 Tahoe '07 5.9 Mega Cab 2wd/G56-SOLD
How will it be 1.25" and 2.5"? And who are you loookin at getting them from? I want some real bad.. If I can get some shackles, im gonna put the over load back in so i have some payload if i need it.. Let me know man. Thanks
They have 3 sets of holes, stock, 1.25" and 2.5"s.
Don Thuren makes them for 4wds and basically the shackles/hangers for the 2wds/4wds are the same just flipped over. So offers lift for 4wds and lowers 2wds(if they fit ok)
Im going to get them ordered this week and he said they take two weeks to get, ill try to get them in as soon as I get them....
Make sure of the diameter of the hole in the shackle is large enough for the bolts on your truch.I had bought a set hoping it would work but the bolts on my truck were larger than the shackle
Kenner LA
07 2500 Quad Cab 2wd Auto,Volant Air Intake,Bullydog, Straight pipe,Quadzilla Boost Fooler
__________________ Click HERE To Find Out How To Help Bring <-- THIS 8 sec Diesel Drag Truck from THAILAND to the NHRDA World Finals in Ennis, TX September 28th
