ball joints - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 02-12-2009, 01:09 AM Thread Starter
2003_Ram's Avatar
ball joints
Anybody have some good ones? Need company names, website, etc. Mine went out and I want to replace them with some good crap.
'03 Dodge Ram Sport Long Bed 6 speed, AFE intake, Banks 5", 35's, Warn winch, Banks 6 gun, 4" superlift....... Some other mods...
[B][I]
2003_Ram is offline
post #2 of 37 (permalink) Old 02-12-2009, 01:47 AM Thread Starter
2003_Ram's Avatar
bump for the night
[B][I]
2003_Ram is offline
post #3 of 37 (permalink) Old 02-12-2009, 08:57 AM
I got Napa Premiums....pretty sure they are Moog's, but even if they arent they are lifetime warranty.
04.5 3/4 QCSB 4x4 FASS 95GPH Fuel system, HTS Ultimate Duty Trans w/ Billet Input Shaft, Laminated Flex Plate and Suncoast Triple Disk TC, Rokktech Adj. CPS, Edge EZ
1975 Jeep CJ-5 304 V8 TF-999 auto & Lifted w/ 33's
justinj is offline
post #4 of 37 (permalink) Old 02-12-2009, 12:29 PM Thread Starter
2003_Ram's Avatar
Moogs, I'll look at those. Anybody else has anything to look at?
I looked around and found stuff. Posted a new thing in dodge 3rd gen non powertrain. going to do the whole front end and upgrade any cheap/crap OEM stuff.
[B][I]
2003_Ram is offline
post #5 of 37 (permalink) Old 02-12-2009, 04:09 PM
Jimmy_pop's Avatar
these are the best prices ive seen for the moog so far. i have not yet searched for a discount coupon code for them though.
RockAuto Parts Catalog
darm the direct link didnt work. the ball joints are listed under "steering"
Jimmy_pop is offline
post #6 of 37 (permalink) Old 02-12-2009, 04:30 PM
critter getter's Avatar
looks like they have some good parts and prices
04.5 2500SB/QC 4x4 white 48re edge-att 6" topgun lift 325x65x18 nitto grapplers on 18x9 moto metal 950 106,500miles
2010 2500LB/QC 4X4 silver SLT stock for now but not long 100 miles
critter getter is offline
post #7 of 37 (permalink) Old 02-12-2009, 04:36 PM
Ontario Chapter President
CumminThru's Avatar
You aint gonna need to look any further, YOU got the best of the best on your mind right now. Costly yeah, quite a bit more than regular non greasable ball joints BUT go to a reputable parts joint and actually look at the 2 side by side, weigh the difference for yourself.
Good Luck!
Dan - Ontario Cummins Crew President
Facebook -
GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07
My new ride - 09 Ram, For NOW .... it's got one of them damn HEMI'S in it.
CumminThru is offline
post #8 of 37 (permalink) Old 02-13-2009, 12:06 AM
if you want to put the the last set of balls ever on the truck go carli, their on the web, baja tested, can't put a scratch on them
07 3500 5.9 6spd ,g56, prodigy brake contrller, amsoil everywhere,gooseneck, single axle, line-x, Bilstein 5100's
gharry is offline
post #9 of 37 (permalink) Old 02-13-2009, 04:42 AM
The best ball joints for our trucks are the ones made by Carli.
Dodge Ram HD Upper Ball Joints - Dodge Ram Suspension System Components
'05 2500 4x4, G56, BDTD CL, AEM Brute Force, High Ram, Monster Exhaust, AD 100, and some other stuff.......
Thanks to John @ Holland Court Diesel
mattingly is offline
post #10 of 37 (permalink) Old 02-13-2009, 04:49 AM
kstinson's Avatar
I have used Moog suspension parts for years and everyone i have purchased was better than oem. However that's not to knock Carli, it looks like they have some fine parts.
2000 Black Dodge Ram 3500 Dually 5.9l 24-Valve, NV5600 6-Speed, Edge Juice/Attitude, AirDog 150, Hydroboost to keep the front end lubricated ;-)
kstinson is offline
post #11 of 37 (permalink) Old 02-13-2009, 08:14 AM
JohnnyU's Avatar
Here's some more good information:
QUAD 4 x4
QC/SB, Autometer triple gauges, Donaldson M090544 5" tip, 1.5" leveling kit, H2's, 315's, Bilstein 5100's
JohnnyU is offline
post #12 of 37 (permalink) Old 02-13-2009, 08:35 AM
Jimmy_pop's Avatar
i dunno about that. after reading this, the upper ball joints dont seem to be the weak link, its the lowers, which carli doesn't make. curious isnt it ...
quoted from here:
QUAD 4 x4
"Premature Ball Joint failures on 2003-up Ram Trucks is a reoccurring problem that will probably plague these trucks for their entire life due to the size of the Ball Joints and the steering geometry of the AAM 9.25" axle.
The Upper and Lower Ball Joints on these axles are at different angles, in other words the vertical axis of the Upper and Lower Ball Joints are neither inline or parallel to each other. To compensate for the different arc of each Ball Joint during turns, the modest sized, straight shank, 7/8" diameter stud of the Upper Ball Joint is vertically free-floating in a 1" long sleeve. Consequently, the Upper Ball Joint does not support any weight, it merely keeps the knuckle in place. In fact the upper Ball Joint is not really a Ball Joint at all, instead it is a floating King Pin that is about the same diameter as the King Pins found on 1966-1981 Ford F100 4x2 1/2 ton trucks and light 3/4 ton trucks with GVW's of 4,700 lbs-6,900 lbs..
The Lower Ball Joint is load bearing, in fact, the two Lower Ball Joints carry 100% of the front axle weight on your 2003 or newer Dodge Ram truck. Dimensionally, the outside diameter of the Lower Ball Joint is only 4% larger than the Ball Joints used on 1972-1986 Jeep CJ's (and other light-duty models of that era) which has somewhere between 1/4 and 1/3 of the front axle weight of the Dodge Ram, plus both the Upper and Lower Ball Joints on the CJ are load bearing. In addition, the Ball Joints used on older models like the Jeep CJ and 1994-1999 Dodge Ram 2500 and 3500* shared the same vertical centerline axis and were pre-loaded to compensate for wear. With the AAM front axle steering geometry using differing Ball Joint angles, no preload is possible, therefore, any wear means loose Ball Joints.
Yes, lack of lubrication with the factory AAM Ball Joints can be a factor, however very few of the failed Ball Joints we cut apart are suffering from a lack of lubrication. Replacement Ball Joints in both greaseable and non-greaseable versions are available from quad4x4.com, plus there is even an offset upper Ball Joint out there (which in my experience is both short-lived and of limited use). Installing Greaseable Ball Joints and regularly greasing them may provide longer service life, but with the AAM axle, chances are you will need to replace the Ball Joints on your 2003-up Ram 2500 or Ram 3500 4x4 truck every two to three years. One would not mind the short Ball Joint life so much if these trucks steered better than previous models, were not subject to "Death Wobble", or had longer tire life."
