Old 02-06-2009, 01:08 AM   #1 (permalink)
PUREVIL's Avatar
How Much Is To Much EGT?
Finally the roads dont have any snow or ice on them so I went out screwing around with my smarty/edge combo and I noticed when I was doing a few 1/4 mile runs that it EGTs went as high as 1300 and I think it stopped there. It got me wondering how much is OK and how much is not good. I have a stock turbo and manifold.
On a side note how reliable is the 1/4 test on the edge? Anyone know? With the Smarty on 6, and the edge on 0 I ran a 14.0 @ 102, and on level 5 I ran 13.5 @ 106. I believe I set the max egt to 1300 to be safe so it may have been backing down, im not 100% sure how this all works now. LOL Im a noob, I can admit that!
2005 Ram 2500 5.9L QC SB. Lots of mods.
2007 Ram 2500 5.9L MC SB. Kelderman Air Ride, Mods Coming!
PUREVIL is offline   Reply With Quote
Old 02-06-2009, 01:13 AM   #2 (permalink)
GA CUMMINS CREW PREZ
SOUTHERN SMOKE's Avatar
is it your 2k5?? an 1300 is fine, the cr trucks run hotter than the second gens, just my edge i set it at 1250* but some guys with the earlier 05-06 models are seeing 1300* stock when they are towing trailers, you are perfectly fine, if you want it to run a little more you can set the back down at 1400* for the qaurter and you will be fine, remember its not just heat that messes things up, whats your boost numbers looking like? drive pressure will kill your headgasket, if you get to far out of your efficiency range, your drive press will skyrocket, you want it to be significantly lower than your boost pressure, but as far as temps go, you have nothing to worry about at 1300*, bump it up a hair more...
CLICK -------> GEORGIA CUMMINS CREW
SOUTHERN SMOKE is offline   Reply With Quote
Old 02-06-2009, 02:09 AM   #3 (permalink)
04dodgedsl's Avatar
1300 is fine. You dont want to leave it there for 20 mins, but for a short quarter mile run 1300 is nothing. Mine will hit 1500 in the quarter, and have some friends that peg a 1600 degree gauge in the quarter. As for the edge quarter mile time, seems pretty fast to me. Do you have your tires calibrated?? I ran a 14.2 on stock tires, and everything in my sig except turbo/injectors.
Gone but not forgotten 2004 Dodge 2500, 4x4, Goerend w/ some Billet stuff, Silver 62, Flux 2.5's, Studs, AFE stage 2 intake, AFE intake manifold, ISSPRO gauges, FBD 5" turbo back, Airdog 150, PPE Hot, Dr. P. Suspended by Thuren, Carli, KORE.
04dodgedsl is offline   Reply With Quote
Old 02-06-2009, 03:08 AM   #4 (permalink)
PUREVIL's Avatar
ok I wasn't sure how high I could go and I searched and didn't find any threads on EGT temps. I'll pump it up to 1400. I believe the max boost is 39 or 40.
While Im asking... the stock turbos dont have a blow off valve right? When I let off the gas under heavy acceleration the sound im hearing is compressor surge right? Is that not good for my turbo?
Old 02-06-2009, 03:09 AM   #5 (permalink)
ok 35-38 is the max of your efficiency range, then your drive pressures start climbing, i wouldnt hold it anything above 40 lbs if it gets there, not saying it cant hold it, but just to be safe on the stocker...
Old 02-06-2009, 02:38 PM   #6 (permalink)
No BOV's. Surging or barking? Surging is "normal" but barking is not good...
Quarter sounds about right...gears pretty much "canceled" out your wheel size, right?
rocket is offline   Reply With Quote
Old 02-06-2009, 02:51 PM   #7 (permalink)
PUREVIL's Avatar
Well how can I tell the difference between surging and barking? It sounds kind of like a bov when I left off the throttle.
I think the 4.56s may be to short for 37s... because now I run 2000 to 2100ish @ 75 mph. For 37s I think 4.10s are fine, but later on after I get some more parts, tranny, turbos, etc. Im going to lift it more and run 40s, then the 4.56s should be perfect.
Old 02-06-2009, 03:02 PM   #8 (permalink)
ynots57's Avatar
if your getting on it and quickly let off the throttle thats barking you hear, your turbo has an electronic controlled waste gate, no blow off valve.
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is online now   Reply With Quote
Old 02-06-2009, 03:06 PM   #9 (permalink)
PUREVIL's Avatar
I thought the wastegate bleeds off excess boost so it doesn't go over 40 psi?
So that barking sound is bad right? When sometimes even under normal/mild acceleration and I left off to maintain highway speeds it makes the sound, its quiet but I can hear it. Sometimes when I let off completely its really loud. If I could figure out why my stupid camera cant be seen on my mac I'd get video for you guys.
Old 02-06-2009, 03:09 PM   #10 (permalink)
Poor Man Built
Dreadnaught's Avatar
if your building high boost psi, then let off fast, its barking. the pwooosh you hear under normal driving is excess boost still in the system, thats normal.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A, Air Dog DF-165
RP, FP, and Studs on the way.
Dreadnaught is offline   Reply With Quote
Old 02-06-2009, 04:36 PM   #11 (permalink)
Okay...those numbers sound pretty good then since you're "geared" low.
There's a natural "whooshing" that your bound to get when the engine no longer fuels the turbo but barking is when it's so excessive the turbo is stopping/spinning backwards. Bark will be "whoosh whoosh whoosh"...hence "barking"...
Ignore the IGNORANT TITLE..this is turbo bark
'04 Cummins Blow Off Valve- Video
Old 02-06-2009, 04:51 PM   #12 (permalink)
THEGreenGoat is offline   Reply With Quote
