if i hook the HIDs direct they work fine its only when i use the factory light plug to switch on the ballast that they flash i dont know if the "lamp out" light has something to do with it or what when i plug the right side factory 9007 lamp in it will stay on but with no lamp on the left it will have a alternating voltage drop fom 12.48v down to 11.30v
thanks i'm going to give the resistors a try i kinda figured thats what i needed but didnt know what size or where to install again thanks alot
You need two 8 ohm 20 watt resistors, t-tap on end to the low beam wire on the factory socket, then take the other end to a good ground, do it on both sides, it worked for me
2006 Ford F350 SRW.....awaiting cummins swap
Thanks to all for the responses
it took 4ea 10ohm 50watt resistors or at least that is what i ordered from ebay to cure the problem
as far as the lamp out light i had to connect the resistors to the right side headlamp connector as well so far all is well with the HID lights again thanks to all for the help
so far they are great well worth the time and money to hook them up
i can't tell the difference between hi beam and low beam there is just a little difference but not much need to install a set for the driving lights next
There really isnt differant between the highs and lows because its the same bulb it just pulls the bulb higher
