heater won't go to floor - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 01-25-2009, 09:38 AM Thread Starter
My brother-in-laws 03 will blow heat everywhere but the floor. Any ideas what could be wrong?
gwhammy is offline
post #2 of 11 (permalink) Old 01-25-2009, 09:43 AM
joelc79's Avatar
I have the same problem, as well as the fan speed is only high or low. I think it is the heat/ac controller it self. I have ordered one off ebay, keep you posted when it arrives
Redline Diesel Power - F1 - Floor It - FTE - Stainless Diesel
joelc79 is offline
post #3 of 11 (permalink) Old 01-25-2009, 09:46 AM
"MR. ESAFO TO YOU!!"
ESAFO's Avatar
iTrader Score: 5 reviews
turn switch to floor section!! . common problem, blockage in the flapper. could b a mice nest or even something smaller. or the floor damper is busted. pull the underneath out from the dash, you'll see the tubes. ggod luck!!
BOB
EFI Live/Smart/Edge, Bio/Solar powered, leveled on 27.5's, carb back straight pipe/14in tip, custom aerosol spray painted by a midget 'MOPED'
ESAFO is offline
post #4 of 11 (permalink) Old 01-25-2009, 11:30 AM
Darknight's Avatar
I had the same problem. Mine fell under warranty though, and they had to re-calibrate the heater system. Not sure exactly what that meant, but the damper as well as the blower worked fine afterwards. Took about a half hour, to do, and I will call my guy and find out more about it.
Black 06 QC 4x4 6spd, 4" straight with 5" stacks,T Empire Bars, HBS leveling kit, Smarty Jr, & cold air kit!
Darknight is offline
post #5 of 11 (permalink) Old 01-26-2009, 02:11 AM
There are 4 sets of doors for the hvac unit in you truck. I say sets because some operations such as defrost have 2 small doors instead of one larger one such as the floor vent will have. These have electric actuators instead of vaccum. Either the actuator went out or little plastic door stop tabs broke(which is usually what happens) Since you have no heat in the floor, your floor door is where the problem is. Sometimes the connector from door to actuator strips out also. You cannot get to this under the dash. The complete duct assembly must be pulled from dash. Here is a link that will give you some info HVAC removed and understood! - Dodge Diesel - Diesel Truck Resource Forums
rooster108bm is offline
post #6 of 11 (permalink) Old 01-26-2009, 07:25 AM Thread Starter
WOW, it's amazing how complicated they can make something simple be. I wonder how hard this unit is to remove and replace?
gwhammy is offline
post #7 of 11 (permalink) Old 01-26-2009, 08:59 AM
ESAFO's Avatar
DAM boy, u just ruined his day!!! that's a crock of SH-T!! hey i was hoping it was as easy as the old day's. my suggestion, put your setting on mid range (face & hands), turn it up higher!!!! good luck!!
BOB
ESAFO is offline
post #8 of 11 (permalink) Old 01-26-2009, 09:20 AM
Fisherguy's Avatar
Thumbs up
Good post!
(I just hope I never have to do that job)
06 QC 3500 stick, DiPricol, stock airbox mod, EFI, Pac Brake, Airlift, AD100, SB OFE, Kore, Thuren, MetalCloak, Bilstein, BD; 295/70R18 Cooper AT MAXX on 2014 factory 18's; 07 Komfort 274TS
Fisherguy is offline
post #9 of 11 (permalink) Old 01-26-2009, 10:33 AM
MotorCityMadman's Avatar
My 2nd gen will go defrost only on very cold days. Other than that it switches fine.
98 2500,4x4auto,48re vb,billet single,shift kit+, Super B, 4" ss,#10 ff,4gsk,.024s, 5x.014, BHAF,16* gauges,WVO, B164 bypass 2004.5 3500, SRW, FASS WVO, B164 bypass, Edge@1 Sold 96 2500 eclb 3gsk
MotorCityMadman is offline
post #10 of 11 (permalink) Old 01-26-2009, 06:11 PM
Semicrazy's Avatar
There is a TSB for the 03s, very common for the doors to break on these. Have seen it on some newer trucks as well. My 03 is the same way.
03HO, 6spd, 5in stacks, BHAF/Cool Hose, Smarty/EZ, AD150, 3250DD, HTT62/71, Fluidampr, Isspro EGT-FP-Boost & Quad RP, Leveled...06, LBZ, Transgo Jr, 6" lift, 6in stacks, Edge Race, Raptor...07, LBZ, 7in Lift, 35s, Banks 6gun, traction bars
Semicrazy is offline
post #11 of 11 (permalink) Old 01-27-2009, 10:16 AM
HOBrian's Avatar
The mode door is not working right! My 03 has the same problem The servo connected to the door is stripped. The servo turns but the door does not move. Adding to the problems is that the door has to pivot up to block off the defrost. Since the servo connection is stripped and the fan is blowing air at the same time, the door does not move because the air blowing is keepin the door in the down position which blocks off the floor vents. I got luck this year in that I got my door to block off defrost and I have not moved the knob or turned the system off and I do not plan on either until the weather gets warmer, because if you do you will never get it back. God I love is dodge
2003 305/555 NV5600 QC SB Sport: Bed rug, sportsmasters TC, RS9000X, seat heaters, boost,pyro,FP on A-pillar, Quadzilla, Amsoiled
HOBrian is offline
