Fan noise - Dodge Cummins Diesel Forum
Old 01-10-2009, 02:42 PM   #1 (permalink)
mauls's Avatar
Fan noise
I'm getting this horrible noise out of the fan located under my glovebox. The one the runs when I use my heater.
Sounds like a bearing is out of it, is this an easy fix?
Any info would be great!
Thanks in advance
2005 Dodge Cummins quad cab 4x4 : de-ringed, Afe stage 2, straight pipe, recon smoke cab lights, 2" leveling kit, 18" prova black wheels, 35x12.50x18" BFG M/T T/A
mauls is offline   Reply With Quote
Old 01-10-2009, 08:39 PM   #2 (permalink)
vreihen's Avatar
Dollars to donut spares, the recirc door fell off and is covering the fan blades. It's three screws to yank the blower motor, and there's plenty of good posts in the archives for how to remove the broken door and fix the problem.....
2006 Ram 2500 SLT QCSB, 4x4, 6-speed G56 manual, VDO blower motor upgrade, panic button and recirc door delete mods, Diamond Eye 4" stainless cat-back exhaust
vreihen is offline   Reply With Quote
Old 09-04-2012, 09:19 PM   #3 (permalink)
I'm getting an occasional fan noise from mine, too. It sounds like you described. Bearing noise, or kind of like a screeching howl from the blower fan. I turned off the A/C (snowflake button), and still had the noise. Tried changing the fan speed, but it stays at all levels. I checked the recirc door, and surprisingly it is perfectly in place (maybe previous owner already repaired)?. When I shut the blower fan off, obviously the noise goes away. Usually if I wait a few seconds and turn the fan back on, it is fine. Wondering if this is a warning sign that I can repair now, instead of suffering w/ no A/C or no defrost. Thanks,
*SOLD* 2000 F-250 7.3 PSD, 6 speed, 3.73, DIY exhaust brake, 247k
2006 2500 Megacab 4X4, SLT, B&W TurnoverBall, Prodigy brake controller, Ranch hand front end, BD exhaust brake
underp2 is offline   Reply With Quote
Old 09-04-2012, 11:05 PM   #4 (permalink)
Pull the blower out as mentioned above and inspect it. It should spin freely with no noise. Its easy to replace, takes only a minute. You'll spend more time at work making the money to buy it
'03 2500 QCLB 4x4 47RE One Piece Driveshaft
TruckPC Custom Ignition System Wiring
superman279 is offline   Reply With Quote
Old 09-04-2012, 11:28 PM   #5 (permalink)
May have a rats nest in it causing the sound
2005 Dodge Ram 2500 HD4X4 5.9 101k miles. Carli BJs, 08+steering with fox stabilizer, smarty jr. And a few other little things
More carli to come. 2007 Yamaha YZ450F
CB90 is offline   Reply With Quote
Old 09-05-2012, 12:17 AM   #6 (permalink)
spins freely. turned on at different fan positions. no problem. It only does it intermittently, so I'm having a hard time reproducing it...
Old 09-05-2012, 12:18 AM   #7 (permalink)
nope. no rats in there.
Old 09-05-2012, 08:07 PM   #8 (permalink)
vreihen's Avatar
I just had to replace the blower motor in my 2006 on Monday. From looking online, there are at least four different manufacturers making replacement blower motors, and Autozone even keeps them on the shelf at our local store. Must be a common failure.
The symptoms on my truck were the blower occasionally not working when I turned the key on, which was fixable by hitting the motor with my hand. Over the next few weeks, the lower two fan settings didn't move any air to mention, and Sunday was the last straw when full speed was barely blowing like the slowest setting on a long drive home. I pulled the motor out and turned on the key with the fan laying on the floor plugged in. It barely turned, and then stopped after a few seconds on full speed, and needed to be spun by hand to get it moving again. I didn't feel any play in the bearings, and the impeller spun with no apparent binding. The only thing that I can think of is that one of the brushes went bad, since it didn't blow any fuses when it stopped turning.
Long story short, the replacement part is available online starting at around $40, and can be found locally for under $100. It's nice having the low speeds back on my air conditioning.....
