I need help confirming if my power steering pump is going out. Every time am backing up while turning my pump squeal and I am not at full lock yet. It does not do this when I am going forward or sitting still in reverse and turning the wheel. If it going bas what is the best to replace it with OEM or what is a good aftermarket one. Thank for the advise. I have an 06 QCLB 4X4
do a really good bleed of your power steering pump and system ( jack the front up, and with the motor off and the cap off the power steering resivor turn the wheel back and forth about 30 times
thanks for the advise. seem to work I will tell a little more this week when I actually drive it to work instead just around the block.
