Currently running a 37x13.50r18 found a good deal on a set of 37x12.50r20. I have 2" bushwacker style fender flares and do not want the tire tucked inside of them to much. Not sure if my current wheels have an offset. Should I get a wheel with a lot of offset or look into spacers if the tires are tucked under the fender more than desired?
depending on the tires actual measurements when mounted, you probably wont notice the difference. but then again, some tires measure out alot different when mounted too...
My 36x13.5 IROKs measure out 37x15.5" mounted and inflated on a 10" wide rim
