Does anyone have a problem with their driver side window freezing up during the winter? Mine freezes up constantly. It only seems to be that particular window doing it. Maybe I blow too much hot air and it freezes...Anyone?
"Every word every thought every sound. Every touch every smile every frown. All the pain we've endured until now. All the hope that I lost you have found."
For those of us from the sunny ( and much warmer ) Okanagan that is a very silly question. However as a former Northern Albertan I can advise that a frozen driver side window is not uncommon. I usually found that it would thaw itself out in about half an hour of running, or just about when you arrived where you were going.
Similar problems here, but I have found that if after washing you hand dry the window gasket (rubber) the the window edge, much less likely. the other thing I do is wipe the gasket with a silicone lubricant which helps a bunch too.
2008 MegaCab 3500 Laramie Auto, Not STOCK Anymore.......
If you park ouside and it rains or snows, it's gona freeze. Get a couple of good magnets and a plastic bag large enough to cover the window.....it works very well .:thumbsup
__________________ Tim
2010 3500 Reg. Cab C&C 4X4; G56 ;EBY Built Flatbed ;H&S Black Maxx; Bunch of stuff fell off; S&B CAI,South Bend Dual Disc
Someone told me a long time ago to get some motor oil and just wet the door seals, I would think just enough to cover them good but not to have them be dripping, unless you want oil down the window. Never tried it but I would think it would work.
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 322k miles #100 plate, SB Con O, 26.6MPG-55mph
