I just bought a 06 3500 4x4, drove it home from the dealership at night for the first time and turn on the lights and.... low and behold the lights on the heater controls, switches are barely readable because the lights are so dim and this is with the dimmer switch all the way up! The gauge cluster was good and very bright, everything else bad though.
Curious has anyone replaced the bulbs with something brighter or found a problem that led to select items being less bright than the gauge cluster?? Its so bad I need to turn on the cab light to see the heater functions and window switches.
Also what control's are supposed to light up? Some are not lit but I dont know if they are supposed to?
-heater (dim)
-4x4 control (not lit?)
-air bag key switch (not lit?)
-foot pedal adjustment (not lit?)
-cup holder light (dim)
-mirror controls (not lit?)
-window controls (dim)
-door lock (not lit?)
-Gauge cluster (dim)
Not sure if there is anything I am missing...
-aftermarket stereo not hooked up to dimmer
-heater (dim)
