Well I tried the led H13 High/low headlight bulbs in my 06 and with the truck not running everthing works great but whenever you start it the low beams flash 3 or 4 times and shut off and will not turn back on then when you change to high beams everything is fine:confused013: anyone else have this issue
The computer is detecting a bulb out condition and in dodge's stupid design they shut off the lights. HID installs have the same issue and you need the same fix. You need load resistors on the low beams so the computer thinks the bulbs are working.
Searching now, any links? Are we talking multi led's like a hummer brighter than daylight or similar to a light bar? Or just 1 bug 10 watt in the middle?
Yeah that's y I tried the led lights cause I knew the hid's needed the resistor but oh well I'm goin to try the resistor Monday.
These are just the 2 big LEDs one on each side for high and low
author=cumminsfirefighter link=topic=12740.msg262480#msg262480 date=1394136039]
Here it is. At about 35 feet from the door. stock to the lifetime leds.
That picture is NOT an improvement. See how the halogen stock lights focus the light in the before image, while the led kit just throws it everywhere. My guess is that there is a reason they show it against a big white garage door, rather than down a dark road a hundred yards or so....
It's not rocket science here, honestly. The factory housing is designed to reflect the light of a halogen bulb (with a glowing filament). This led produces light (and if there was some real science applied less of it), from ONE side of the "bulb"... These lights are toys, not safe or effective, but good luck.
Not my photo. Don't know if it was low or high. And let's not go down the HID (and LED) in a reflector housing debate. They (Lifetime Led) state that they are DOT compliant. Someone wanted to see these and I have been watching a thread on them so I posted it.
I was the one that wanted to see them because I wanted to see if they had any kind of decent pattern. Sorry to say they appear to pattern worse than a HID conversion bulb.
I'm also wanting to change my light for better "down the road" light too still investigating the LED's.
