My left reverse light doesn't work but it has 12 volts and a new bulb? The left turn signal on this same side only works when I remove the reverse bulb? Otherwise it's just a dim flicker. Anyone else had this problem? Or know of a solution?
Apparntly my meter is less of a load than the bulb that I know is good. I read 12 vdc so to me it seems like it could be a bad ground somewhere?
