I do think the unit works good. I just need to do a more perminate and cleaner install. I couldn't place it in the plenum because the of the pressure provided by the turbo. I need to either build a venturi or buy one. The venturi that comes with the unit is not a true venturi, more like an injector that places the gas in the center of the cold air stream. The unit needs a vacuum to pull the hydrogen into the engine. I also didn't get teh right water. I grabbed the drinking water instead of the distilled. That may be where the larger amount of rusty water is coming from.
Scott
2006 Ram 2500, SB, 4X4, Auto, Edge, 5" home made air tube, Magdrive HHO, stock exhaust.
