Originally Posted by gstanfield
So far nobody has ever blew one up, plus if you tap the pressure side of your intake then you're going to have to run more propane pressure than boost pressure or else it will just blow backward and no propane will ever enter your engine.
Think about it, 1.5psi of propane trying to force itself into a intake with 5psi running steady or 35psi going up a hill??
Feel free to not use propane, it's not for everyone that's for sure.
George
Dude, what are you talking about?
Propane or N20 is going to be injected into the engine the same way. You think 2 psi is not going to get sucked into the motor? 35 psi would suck you girlfriend into the motor if you stuck her head in there
99 CTD DRW 4x4 Auto~ SLT Laramie quad cab~4:10's,
Edge Juice w/Attitude, MBRP 4" turboback, AFE Pro Dry S Stage 2, Airdog 150, Amsoil Bypass kit, Bilstein 5100's, HBS leveling kit, upgraded IC boots, BFG commercial T/A traction's,
