Old 05-08-2006, 03:52 PM   #2 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Check for power coming out of the stock harness. Make sure you are not getting a signal from the ECM. If no power, check the relay and make sure its not stuck. That can happen every once and a while. You can check it with a relay out of the fuse box. If you are getting power from the ECM when the key is cracked.....you might have issues beyond what i can help you with!! haha....
This is a weird one......but i would think that the relay is stuck on...that is my guess right now......
EDIT.....DUAH...if the relay stuck....it would run all the time........haha...next day after some sleep....
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
