I have seen 7psi on mine sometimes if I'm not mistaken the flow rateing is more important than psi the stock pomp is rated at appox 40-50 gpm bd pump is rate at 100 or 120 cant remember
2001 HO 225k 6 speed juice w/att, 100hp jammers, 4in exh, s&b intake, bd lift pump, south bend ofe, 3in spacer, pro comp s9000 shocks, 35 nitto terra grapplers devils own water/meth under the tree
