Old 12-16-2007, 11:46 AM   #4 (permalink)
gmctd
Tech Specialist
Correct - the CP3 will pull 20" vacuum on the line to the tank, drawing fuel - the Jeep doesn't have an aux lift pump, always running in the draw-from mode - depending on the a\m pump, if it is drawthru-type, the CP3 can draw fuel thru it without the bypass - any 2micron filters will add some restriction over the oem 10micron.
Even if it won't win any races, it'll still getcha home................
If it's a Diesel thing, I do understand..................
96 Dodge 3500 CC 2wd drw 3.54\6sp 5.9\12v TST#10 SBC13" '05-17"whls Buckstop
DODGE makes it - CUMMINS shakes it; 6 in a row makes it go
gmctd is offline   Reply With Quote
