Old 12-16-2007, 10:56 AM   #8 (permalink)
Smokin 5.9
Smokin 5.9's Avatar
Originally Posted by cummins2001man View Post
just got new bd oem buypass pump on it only reads 8-10 at idel and 5-7 at wot is this normal.does anyone else have this pump,or am i in the dark on this .any help ....
I ran the auxiallary pump for awhile with a new pump at the block and had 32psi at idle and 28 at wide open throttle, you should see about 15psi at idle
00 QCSB, AFE, 5" Miters, Injs., HRVP44, Edge Drag, Redline, Gauges, SB DD, S400 w/ Manifold, & Hose & Clamp Kit, CD Timer, Head Fireringed, Port & Polished, HD Valve Springs, A-1 studs, Haisley Street Grind Cam, Fluidampr, Water/Meth, PSI fuelsys.
Smokin 5.9 is offline   Reply With Quote
