Old 12-16-2007, 09:10 AM   #20 (permalink)
slagburn
Diesel Poser
slagburn's Avatar
Originally Posted by TC_So Cal View Post
Slagburn,
You are absolutely right on. Scary really, Some years ago that issue would have simply been a voltage regulator problem and had no effect on the diesel at all. Progress????
Makes it difficult for us shade tree mechanic types; almost every procedure in the service manual starts with "Connect Scan Tool" and very little content about using a DMM to check for faults at various places.
Originally Posted by siouxland express
I was told that the reflash portion of this G30 recall is to narrow injector pulse width, resulting in less power output. I was told this by the technition that would be doing it to my truck. I have reservations about letting them nuter my rig.
First I've heard this, mine has been pretty much the same in terms of gauge readings and seat of the pants power which is usually a lot more than the rear tires can put to the ground.
Originally Posted by coopsbft
hey does anyone know if the dealer has to order the parts for you or should they have them there.
I had to call numerous times and eventually spoke with the parts department to get the stuff I needed, kind of a joke but helped a lot when I showed up for th recall along with another guy who hadn't called ahead.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
If we each have an object and exchange them we still each have one object - If we each have an idea and exchange them we each now have two ideas.
slagburn is online now   Reply With Quote
