I hope people post their results good or bad. I wouldn't worry about the motor taking a little water through the intake. The water injection kits are sopposed to clean up carbon and not be hard on your motor. I know the water won't be atomized, but it should be such a small amount I don't think it will have any ill effects. I have pulled the boot off at the intake manifold and wiped water out of the bellow many times. If the kits are mounted lower than where you tap into the intake most of the water should run back to the unit, shouldn't it?
6/06, MegaCab, dually, 4x4, g56, 3.73's, S-06, 75hp sticks, ARP's, HTT62/65/13ss, ATS ex/man, cfm+, HGD, FASS150/95, 1R-0749, Quad BF, PG-7, PRXB, SB3250 sh dd, Fluidamper, air bags, Fastcoolers, mag-hytec diff covers.
