Update. I got the truck back. They cleaned it up but it still had grease on the floor mat. I cleaned that myself. When I got it home I cleaned up the transmission also since it had some transmission fluid on the pan and in the areas that they said they fixed. So it has been 2 weeks now and I decided to climb under the truck today. Well guess whats there? Transmission fluid. I have never had an issue like this before. I am almost ready to get rid of the truck......so I guess I will be back in there tomorrow and see what they come up with this time....oh and it doesnt even look like they took it apart. I looked at it every time and the gray sealant looks the same. (missing a small amount on bottom) Also when you do a transmission rebuild do you generally replace the output shaft seal on the transfer case where the drive shaft goes in? Mine is cracked up and doesnt look replaced.
