Important facts to remember using HHO Hybrid
You do not need to make any major alterations to your vehicle.
All late model vehicles are already computer controlled.
Your vehicle computer will make all of the fuel/air adjustments automatically.
You must turn the unit off when not running your vehicle.
You must manually check the fluid level in the HHO gen reserve tank every few hundred miles.
For cold weather climates use a fibre-glass foil backed pipe insulation wrap. [Not Included]
All models come with a liquid/gas flash back safety valve.
straight off their website... it kinda implies that it needs an electronically controlled engine... wonder how that works with the old mechanical diesels?
'99 dodge 4x4 5 speed quite a few mods. north of 400 hp
'07 5.9 G56 4x4 qc 3.73's 1 ton SRW, BHAF and gutted intake, almost straight piped.. CM skirted flatbed
