Diesel Dan i hear you are the man when it comes to FASS here is a few questions for you hopefully you can help me. I have a 2002 ram 3500 flatbed dually my lift pump is 100% dead the dealer wants to put a in tank pump in... i do have a warrentee that should cover this.. but im thinkin of just bightin' the bullet and goin fass. the questions i have are how hard is it to install, wiring, plumbing, etc. also because i have a hyraulic dump the hydraulic pump and resivoir are on the driverside frame rail where i think the fass should be mounted, i can not move the pump becasue of the way its hooked up can i still use a fass, also becasue its a dually my rear tires throw up alot of dirt sand snow salt that direction i imagine that that would not be good for the fass system.
i have a block mounted lift pump right now, it is putting out 0 pressure and 0 volume how long its been like that who knows.
do you feel that this system is the best setup for my truck or is there somthing else out there that i should look into?
if it will work what would i need and what size
let me know what you think please!
2002 Dodge 3500 4X4 cab chassis 24 valve automatic, flat bed/dump bed, full guages, smarty S-03, BHAF, MBRP 304 cool duals....Newbie to the diesel world and loving it!
