Old 11-07-2007, 07:30 AM   #126 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by lxlaw View Post
Will I still need a snubber for the location off of your pump?
I feel a snubber should be a standard item when installing a gauge. SO yes...i feel that would protect your gauge better, and would also restrict the flow of fuel if you ever had a leak on the gauge side so you would have less of a mess........
jbarker,
You are good to go......got you on file.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline
