Old 11-06-2007, 07:29 AM   #122 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by lxlaw View Post
So do you get the same reading at the fuel pressure port on the FASS pump and can I use it to get an effective reading? Or do I need to get it closer to the injection pump?
WELL...if you are at the VP pump, you see what the pump is seeing. BUT pressure drop from Line loss is sooo small, that if you took pressure from our system....i think you would be just fine. The only thing that could not show would be an internal failure of the hose that blocks fuel flow. BUT VERY VERY Rare....
Between the 95 series and the 150 series, not much differance in performance. Both have the exact same pump options. The big differance is size. The 95 series is 25% smaller than the 150 series. The 150 series has filters you can cross to aftermarket sources. The 95 series you will need to contact a FASS dealer to get fuel filters as they are made just for us by Fleetguard. The water separator you can cross to a FG# FS19768 Number.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline
