Old 10-28-2007, 07:40 AM   #4 (permalink)
BBRam
Super Administrator
BBRam's Avatar
Originally Posted by IC-Smoke View Post
Thanks!
In order to change the settings on the NON adjustable (by switch) do we have to take the box apart?
Thanks
Ian
There is a plate on the end of the box, it is held on by 2 screw's. Remove the plate, inside you will see different chip's (For a lack of a better word) there are different configuration's for the chip's inside. Different position's will change the power level's. If you need the direction's Ian, let me know. :thumbsup
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
