Old 10-24-2007, 08:59 PM   #9 (permalink)
HARRISDIESEL
HARRISDIESEL's Avatar
Ok I got a update on Clutch #2!!! When I pulled the tranny out tonight i found that the clutch pack closes to the flywheel--the center where it splines to the input shaft--was just about wore the heck out!! The pressure plate was also screwed up with some button broke!! the pressure plate clutch pack looked good with just a normal wear!! I have a new pressure plate from SBC but I need a hole new clutch flywheel and all!!! and I have to put a new input shaft in my tranny bc the splines have a wear place from the worn clutch pack!! Which sucks bad!!!! But I will get it done!!
02 2500 4x4 6spd 4.10 tst comp t-bars ddp240s FBDs2monster44 scottyair .093 lines bored tubes IIsilverbullet66/74/14 htt manifold fass150 6in miters watermeth oringed studs spearco sbc dd 20s 35in mudgrapplers 240k 10/4/08 537hp 1050t
HARRISDIESEL is offline   Reply With Quote
