Old 10-24-2007, 06:00 PM   #1 (permalink)
DiscountPowerParts1
Larry @ DPP
DiscountPowerParts1's Avatar
03-07 CR 75/100/120 Injectors $600+ Core
Complete assembled injecters with brand new EDM'ed nozzles. Each injector/Nozzle is inspected, assembled, flow tested and verified a match within 2% after EDM machine work.
All core injector bodies are remanufactured with any required electronics and/or mechanical parts to restore 100% integrety.
Simply remove your OEM or failed injectors and replace with complete assembled House Of Power injectors. Send your old cores back to be remanufactured with new hardware/electronics and new EDM'ed nozzles.
Core of $750 on each set.
You choose:
House of Power 75HP $600.
100HP $650.
House of PAIN 120HP $700.
Custom EDM injectors beyond 120HP available.
75HP recomended with OEM CP3.
100HP can be used with stock CP3 and dual feed lines but some users will fail to feed rail pressure and be forced to upgrade to the +45% CP3.
120HP require upgraded CP3 as well as the dual feed line upgrade.
Call us or email for details!
Tuners, Suspensions, Exhaust and other performance parts. DiscountPowerParts.com
Larry
866-547-3517
Sales@DiscountPowerParts.com
*This is a special value being passed onto you at the Cummins Forum Only. Prices on the website are not as advertised here! Limited time offer.
DiscountPowerParts1 is offline
