Old 10-24-2007, 03:16 PM   #14 (permalink)
LaMoparPower
Super Moderator
LaMoparPower's Avatar
Originally Posted by Diesel_Nuts View Post
I am also interested in putting HID's on my truck, and would like to get some info too. lamoparpower, HID's actually run cooler than your factory headlights, and draw less power, so those projector lights will be fine. I want to do the same thing as you, and have done the research on the HID kits. Only problem is getting around the Dodge lighting problems, and I will have them on my truck.
HID's actually run hotter, but use less wattage.... i.e. your heating up gas instead of lighting a filament.... i thought the same thing... but less power doesn't necessarily mean less heat.... halogen and High Intensity Discharge produce their light in totally different aspects..... and i have had no problems with just the "bolt in" kit.... comes with bulbs and a Ballast/igniter.... plug your factory headlight plug into the ballast.... then plug the new gasbulb into the ballast....
red 06' quad cab, 33" cooper ZEONs on 20" ballistics, onboard air, Nathan K3LA train horns, H.I.D.'s, no mo' silencer ring, AFE Mega Cannon, edge juice w/attitude w/hot unlock & mp-8, 7" mitres, smoke switch, kenwood nav/dvd indash full system w/2 12's... and.... more mods to come... just waiting on the lotto.... """finally some numbers!! 14.4 @ 98.9MPH on stock tranny and no boost"""
LaMoparPower is offline   Reply With Quote
