04-15-2006, 12:50 PM
#1 (permalink)
What is an ADD .... - A
2002
2001
1998.5-2000
This simple plug-in device allows you to get an additional 10% horsepower and torque from your engine! Add it with injectors for a super combination! When using the ADD with boxes that have a MAP Sensor provision, always plug the ADD directly into the MAP Sensor, then plug the box harness to the ADD. To explain it simply: The ADD has a microprocessor that acts as a electronic voltage regulator, thus never allowing the engine computer to see an over-boost signal.
Thanks To www.haisleymachine.com/
