i work at lott motor co in huntsville if anyone know where that is. anyway i work on all there big trucks from 3/4 ton to a peterbuilt rollback they have
the only thing about a diesel is make shure you have a cleen air filter, fill the new oil filter back up befor you install ill and grease it good o and at 15,000 or so you may wana get a new fuel filter just to be safe i have not been under the hood much on the newer trucks but i know my 1st gen truck it easy fuel filter replace and they may have a self air bleener like the 2nd gen 24v did i duno but the fuel filter can be the bigest pane in the but on a diesel
and if you do the pel filter your self make sure you let the truck run for a good 15 20 min befor you shut it off it can take a min for all the air be get out of the system and it may run a lil ruf for a min untill all the air is out
but its all up to you :thumbsupgood luck
93, 6in lift 36in tires
Cummins all the way baby
