đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.2 replies 124 views
I've seen a few older threads debating the maximum lift pump fuel pressure the cp3 can take on the 3rd gen and newer trucks. I wanted to ask the question and get new info. I've seen it claimed the stock cp3 can handle up to 100 psi of lift pressure how true is this? If that is so why do we see...11 replies 376 views
Hey all, My transmission took a dump out in mountains and I'm looking for some thoughts based on others experience. I've got a 2012 with the 68RFE and min max with I assume 450 hp on the performance tune. Looking for any feedback/thoughts from people with a similar setup that have on Suncoast...25 replies 10K views
