👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I have a edge comp box for a 2000 Dodge Ram 2500. I do not have a wiring harness for it and I contacted edge trying to order a new harness, which I was told they don’t make anymore since my tuner is manufactured in 2005. Will a newer harness work, or if someone could help me find a new harness...10 replies 3K views
Trying to fine-tune my alignment now that I’m on my new tires, stock 265/70/17. it feels like it kind of wanders at high speeds. I’ve got some angle iron I’m gonna make brackets to do good measurements, I’ll take the front wheels off and bolt the brackets to the hubs. Should I do zero, dead...6 replies 137 views
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.0 replies 21 views
I'm going to start this thread again and hopefully it won't go off the rails and get closed. Installed new hubs. Amazing, the truck tracks straight down the road now and doesn't have an annoying click in the steering wheel anymore. Also installed the replacement drag link tie rod since I...8K replies 727K views
