Originally Posted by Dr. Evil
I dunno about that...The Pumps the FASS kits use are pretty stout (especially the ones with the sealed brushes)...although I must admit ive never seen one that was cut open.
But, and this is a big But, they are $$
IF you are a TDR member, do a search on FASS, you'll see enough problem/failures among displayed threads to restore SOME relative faith in the Carters... There's even a poll of FASS failures over there - and last time I looked, a full THIRD of reporting users had problems/failures of one sort or another - and I seriously doubt even the scorned Carter's are anywhere NEAR that failure rate...
The key issue in failure tracking, is number of failures *per THOUSAND* - so if 3 guys in 10 users report FASS (or any similar aftermarket) issues, that SEEMS lots better than when 100 guys show up with Carter LP issues - UNTIL you stop to realize that's perhaps out of 10 THOUSAND Carter users...
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
