I'm really interested in running veggie oil or making Bio. I have researched in depth and see the pro's/cons either way. I also have read numerous University studies which all came to the same conclusion short term use is OK long term use resulted in mechanical issues. For those of you running 2003 and newer trucks has anyone put down 30k or more miles running on it? If so have you seen any mechanical issues? Injector failure, coking, cylinder wear, carbon build up, ect? While I want to go this route I'm not interested in major mechanical issues which eat away the $$$ incentive to do it. Give me your experiences and what you are running whether heated oil or made your own Bio. Thanks
2007 Mega Cab Laramie 5.9 Cummins, Smarty Jr. Jake Brake, 5" MBRP Stainless Exhaust, 48re, Amsoil fluids and oil bypass, Nano filter, Toyo Open Country AT 285/75/17, AMP research power steps
